Hey there!:)
Just wondering as i was at a gig last friday:
I turned on the MacBook, and connected my VMS4.1 and opened up VDJ LE 7, and added a song and played.
Then i heard. The sounds was coming out of the computer, instead of my controller. How can that be?:)
Thx.
Thx.
Posted Tue 12 Jun 12 @ 2:39 pm
same thing happened to me... go to config... audio.... asio, problem should b solved
Posted Wed 13 Jun 12 @ 10:35 am
Thats the problem.
VDJ LE doesnt offer config.
Posted Wed 13 Jun 12 @ 12:58 pm
GO PRO THEN.
thanks, Panos.
thanks, Panos.
Posted Wed 13 Jun 12 @ 2:38 pm
I currently don't have money for that.
It can't be right that i have to buy Pro, for using the software on Mac, when it says on the site that it is compatible with Mac.
Posted Thu 14 Jun 12 @ 11:20 am
Mac doesn't have ASIO - It uses standard built-in CoreAudio instead.
Please see http://www.virtualdj.com/wiki/VMS4%20/%20VMS4.1.html
If this doesn't help, please contact support for direct assistance: http://www.virtualdj.com/contact/index.html
NOTE: You don't need to upgrade to Pro just to get the sound card working. The VMS4 should work fine with the included LE (Limited) version of the software.
Posted Thu 14 Jun 12 @ 12:50 pm
I will check it out, thanks:)
Posted Thu 14 Jun 12 @ 2:34 pm
Hello there..
Yesterday i buyed the macbook pro and i was tryed to install the virtual dj le with pioneer ddj ergo,but doesent work....
i had the same virtual dj le with pioneer ddj ergo to my windows 7 laptop and everything was good.
Ive put the conf button to fix the options but there havent asio soundcard option..
can you help me please?
Posted Thu 13 Nov 14 @ 9:04 am
There is not such thing as "ASIO" on MAC's
MAC's have Core Audio Instead.
Also, since it's a LE version, all you have to do is to go on AUDIO/MIDI setup (on MAC OS X) and set the soundcard of ERGO to quadraphonic mode.
Posted Thu 13 Nov 14 @ 11:21 am
my virtualDj le stopped working what can i do to fix it?
Posted Tue 25 Dec 18 @ 11:02 pm
1) Please don't dig up dead threads - this one was started in 2012.
2) You need to give a lot more info than just saying "stopped working".
Posted Wed 26 Dec 18 @ 8:42 am
