Before I used the DDJ ERGO I used a Numark Controller. So when I am busy playing I always have to change the MASTER player manually after mixing 2 songs. Meaning that when I have done a mix of 2 songs and I want to mix another one in and I have loaded that one into the empty player I first have to manually click on MASTER on the player that is now playing so that I can SYNC the song I wanna mix in. Before it always just worked with the Numark, I loaded up a song, pressed SYNC and I was good to go. It is not a massive issue but when you mix quite quickly you tend to forget to change the master player and stand there wondering why the hell the SYNC button isn't working anymore...
Has anyone ever had this issue? Only started since I use the ERGO... Must be a setting in the options probably but I didn't find anything. I am DJing using the VINYL mode.
The other thing is when I load up some songs into the side list for a autofade playlist and then press the automix button (automix settings are done like I always usde to set them up) it loads the song to be automixed in into the other player and not into the same player underneath the one that is playing.
I hope u guys can help with those 2 issues, otherwise VDJ7 PRO FULL is working just fine on the Macbook Air /w DDJ ERGO - even found a DDJ ERGO skin :-)
Thanks in advance !
Ludger
Thanks in advance !
Ludger
Posted Sat 12 May 12 @ 10:55 am
aqui dj abrahamm como estas fans
Posted Sat 15 Dec 12 @ 1:10 pm
Sorry, this forum is for English language messages only.
Please either post your message again in English or use the appropriate language forum at the bottom of http://www.virtualdj.com/forums to post in your own language.
Also, this topic is about the Pioneer DDJ-ERGO. If your message is not about this controller, please open your own topic.
Posted Sat 15 Dec 12 @ 1:45 pm
try holding shift on the controller then press the sync on the left deck then see if it syncs up, i have to do it everytime i play or it will just sync on the right deck, i use windows but im just about ready for a mac but yeh these things have some wierd things going on in conjuction with vdj
Posted Sun 16 Dec 12 @ 12:53 pm
When using a 4 deck skin, make sure that the deck that you wish to sync to is set as the master deck: http://www.virtualdj.com/wiki/Masterdeck.html
NOTE: Normally, VirtualDJ will change this automatically as you load each song, but this may be disabled in some versions of VirtualDJ LE as required by the manufacturer. To check in the full VirtualDJ Pro, go to CONFIG -> Options and check that Auto Headphones is enabled.
Posted Mon 17 Dec 12 @ 5:19 am
djigsaw wrote :
..The other thing is when I load up some songs into the side list for a autofade playlist and then press the automix button (automix settings are done like I always usde to set them up) it loads the song to be automixed in into the other player and not into the same player underneath the one that is playing.
By default VirtualDJ chooses the MASTERdeck to enable Automix. If you wish to force another deck to be used by automix, assign a keyboard shortcut as..
deck x automix
Posted Mon 17 Dec 12 @ 11:33 am
