I have a Hercules DJ 4 Set and I just upgraded to the Virtual DJ full version can my 4 Set use Timecode Vinyl?
Posted Wed 02 May 12 @ 1:34 pm
Using Timecoded vinyls or CDs is not possible with the DJ 4Set since there are no inputs to connect a turntable or a CD player.
Posted Wed 02 May 12 @ 2:26 pm
If you purchase a suitable external 4-in/4-out ASIO sound card such as Hercules DJ Trim then you will be able to use timecode vinyl. You can still also use the Hercules 4Set at the same time to control other functions in VirtualDJ (Effects, browsing, etc.) as well as use it as a software MIDI mixer.
Please see: https://virtualdj.com/wiki/Timecode%20Requirements.html
Posted Thu 03 May 12 @ 4:53 am
