Forum: Old versions
Topic: Need Help with VMS4.1 Mapping
Just got my new VMS4.1 today and am having major trouble setting up the audio config and mapping for 4 deck function.
I have installed the ASIO driver and virtual djLE (Although I want to use my pro copy). Using it with 2 decks works fine.
Have followed the instructions on setting up the controller advanced sound setup and tried 2 different mapping files from the plugin section but basically I cant get it to work.
I want midilog 1 to be channel 3
midilog 2 channel 1
midilog 3 channel 2
midilog 4 channel 4
Play, Cue, effects, and loops all work fine
but sometimes the volume faders dont work at all.
sometimes they control the wrong channel
sometimes decks 3 and 4 dont give any sound.
I have always considered myself to be pretty good with this kind of thing but it has me stumped and any help would be greatly received.
Using:
DEsktop AMD Quad
3Gig RAM
Windows XP
American Audio VMS4.1
cheers
John
Posted Fri 27 Apr 12 @ 6:21 pm
Hope you fix the problem but if not:
A - For buttons and general mapping: Must use vms4.1 skin provided with the cd or you can download it here.
B: 1 Go to Config, then Sound Settings, in out put select advanced configuration then press the advance config button, then select
Deck1 - adj ASIO (ASIO) - Output 3&4
Deck 2 - adj ASIO (ASIO) - Output 5&6
Deck 3 - adj ASIO (ASIO) - Output 1&2
Deck 4 - adj ASIO (ASIO) - Output 7&8
Press apply, the OK
And thats it.
You should be fine.
PD: When you turn knobs like bass low and high, they dont display in the computer properly. I have the same isue..
