So i'm thinking about purchasing some CDJ 850s, but i'm still on the fence on what mixer i should get to accompany them. I could go a cheaper route and get DJM-350 or 400, or i could go a more expensive route and get a DJM 700. Thoughts/opinions??
Posted Tue 24 Apr 12 @ 10:56 am
Heck, I was gonna recommend the DJM-250 - if your basing your choice around that, why not go in between
Posted Tue 24 Apr 12 @ 4:00 pm
Why restrict yourself to Pioneer?
There are lots of other great mixers (and CD players) out there.
Posted Wed 25 Apr 12 @ 6:13 am
well looks like you have the VMS4 so why do you need a mixer? I also have the VMS4 and 1 Radius 3000. Whit the VMS I can just switch on the front between when I want to use the 3000 as midi or analog. But then again if you want the mixer because of it's FX then I see the point in gettin a Pioneer. I personally also want to get a set of CDJ850 because they work with Recordbox so however I set up my music with cue points and loops I can just bring my thump drives to most clubs and be able to do everything I can do at home. without the need of bringing my setup.
But if your getting a set of CDJ850 and a DJM700 just for controlling VDJ I would say it's way overkill.
Posted Wed 25 Apr 12 @ 7:14 am
Because you can overload the VMS4 mixer in a heartbeat!
It was one of the first things I noticed when I got mine - how easily it could be pushed into distortion.
Posted Wed 25 Apr 12 @ 9:58 am
