Hi guys,
I am having some issues with my set up since a week or two :
When I am using my set up, I can only control the sound of both VDJ channel on only one on my physical mixer.
When I try to change the output from "None" to "2 time code" it says that I don't have enough channel (using ASIO driver for CDJ). But this was perfectly working during the last ten months. I did try to reinstall everything (VDJ, Asio, CDJ drivers, etc...) but it stills not working.
Does anyone had the same issue and found a way to fix this ?
I'll glad to have your help :)
Thanks.
Julien
Thanks.
Julien
Posted Sat 10 Mar 12 @ 6:51 am
