[DjDad Edit]
Sorry Svenino, i tried to quote and pressed the wrong button :P and i deleted your message
Your question was about to display cuenames depending which deck was selected ...
Here is the answer ...
You need to have 2 panels with visible condition
<panel panel="cuenames" id="deck1cuesSel" group="deck1cues" visible="deck 1 select">
<...dimensions and size of the area your cuenames are>
</panel>
<panel panel="cuenames" id="deck2cuesSel" group="deck1cues" visible="deck 2 select">
<...Same dimensions >
</panel>
and then have 2 textzones depending on what panel is on..
<textzone panel="deck1cuesSel" deck="1">
<size width="208" height="31"/>
<pos x="544" y="132"/>
<up x="859" y="2962"/>
<text font="arial narrow" size="29" format="%namecue1" scroll="yes" color="red"/>
</textzone>
<textzone panel="deck2cuesSel" deck="1">
<text font="arial narrow" size="29" format="%namecue1" scroll="yes" color="blue"/>
</textzone>
Same for deck 2
</panel>
</panel>
</textzone>
</textzone>
Same for deck 2
Posted Fri 09 Mar 12 @ 10:54 am
Thank You djdad but I give up.
I tried hours and everything is confused now.
So my cuenames stay white!
Thank You again for Your kindness.
Svenino
Svenino
Posted Fri 09 Mar 12 @ 5:09 pm
Just wanna say THANKS again.
Everything is fine and my Cuenames are colored.
DjDad You made it.
DjDad You made it.
Posted Sat 14 Apr 12 @ 3:36 am
