Forum: Old versions
Topic: Setting up VMS2 - Page: 1
Hey all,
Bit of a crisis situation. I have a gig tomorrow and my brand new VMS2 just showed up today.. tried to take for a test run and I can not get any audio output. The program recognises the hardware, buttons and faders respond, but no audio..
Setup:
MacBook Pro, Virtual DJ Pro 7 (updated)
Audio Setup: Advanced Config> Master (VMS Audio Midi Device) & Booth (VMS Audio MIDI Device)
What am I doing wrong?
Any help would be greatly appreciated, in this my hour of crisis..
Peace
Posted Thu 09 Feb 12 @ 4:50 am
gullumPRO InfinityMember since 2007
you should set
deck 1 > VMS audio midi device > Output 1&2
deck 2 > VMS audio midi device > Output 3&4
Hope this helps although I have the VMS4 but setting should be the same
Posted Thu 09 Feb 12 @ 8:05 pm
I cannot get stereo from my vms2. virtual dj pro. always one side of stereo is missing. Both outputs are functioning but its always 2 left or 2 right. both deck one and two should be putting stereo to the main out put. Almost all rock songs are missing guitar solos or what ever is panned in the mix. Extremely frustrating. I'm set up using the asio driver deck 1 output 1&2 deck 2 output 3&4. I just want true stereo from both sides. ugh.. help please..
Posted Sat 25 Feb 12 @ 12:54 pm
Rudra.....i am having the exact same problem i am using a PC laptop but same exact problems.... did you figure it out? if so how did you do it?
Posted Sun 26 Feb 12 @ 5:18 pm
I just got my VMS2 a few days ago. i set up everything on my laptop; loaded in the Virtual DJ LE disk and opened it up, connected my VMS2, and began working on it. but my songs skip and the whole thing doesn't seem right. sometimes when i load up music, it takes forever. My songs skip and it goes through my speakers. and every now and then, the song i select won't load up period, and i'm convinced that its my computer or Virtual Dj. and then when i would close the program, the program AND my comp would freeze. then i'd have to shut down my laptop, and not the "safe" way either.
Laptop: Compaq, refurbished
I went ahead and got my computer cleaned and put a new windows on it (Windows 7) but when i read the instruction manual, it said that Windows XP Sp2 or Vista was required.
should i clean my computer again and get one of those 2 windows installed on it instead? or is there possible a problem with my VMS2?
PLEASE HELP!!
Posted Mon 05 Mar 12 @ 8:48 pm
This means that you have performance and/or configuration issues with your computer or it is not high enough specification.
Please see the following FAQ pages:
http://www.virtualdj.com/wiki/Performance%20Issues.html
http://www.virtualdj.com/wiki/My%20songs%20load%20very%20slowly.html
http://www.virtualdj.com/wiki/Error%20loading%20song.html
Please also register your VMS2 VirtualDJ LE serial number on the page http://www.virtualdj.com/users/edit.html and download and install the most recent version from the Download Center: http://www.virtualdj.com/download/updates.html
Most computers/controllers should work fine with Windows 7, however if it's an older computer, you may be better off with Windows XP. Vista should be avoided at all costs. Make sure that your computer exceeds the minimum specifications recommended by the manufacturer.
Posted Tue 06 Mar 12 @ 4:38 am
thanks so much. i checked all that; chained my windows 7 to the Basic setting and downloaded virtual dj le7.
the music is running smoothly and nooo stuttering!! *knock on wood*
but my only other problem now is when i'm all finished and wanna exit the program. it freezes up and even when i open the task manager, it still won't close when i try to close the program that way. so i end up having to just use the power button and shutting everything down without warning and that makes me nervous.
i wanna only use this computer for my DJing sooo...
PLEASE HELP!!... AGAIN
Posted Tue 06 Mar 12 @ 8:18 am
This means that there is still something conflicting somewhere on your system that's preventing VirtualDJ from closing properly.
It could be the VMS2 driver itself. You can confirm this by unplugging the VMS2's USB cable when VirtualDJ freezes. If the software starts responding again and closes normally, then it's a problem with the VMS2's drivers. Please check with the manufacturer to see if they have any updates available.
It's also worth checking your VirtualDJ database to ensure that this is not corrupted. Please see: http://www.virtualdj.com/wiki/I%20get%20an%20error%20message%20saying%20that%20my%20database%20is%20corrupted.html
Posted Tue 06 Mar 12 @ 8:56 am
yeah i need help seting up my vms2 with virtual dj pro deck one it it volumes with deck two and the same way with deck two it volumes with deck one
Posted Thu 31 May 12 @ 12:05 am
Do any one know how to set my mapper..i have a dj console mk2 which work good and now i got the hold VDJ Full Pro and now my vms2 now mapper is off..my crossfader is off and when i cue a song...the one thats playing and the one im cue up next u can hear it out load instead in my headphone
Posted Wed 05 Sep 12 @ 8:46 am
Just updated to Virtual DJ Pro 7, but can not get VDJ7 to recognize my VMS2 controller. I have been using Virtual DJ Broadcaster for weddings and then VMS2 Virtual DJ LE for Parties, and would like to combine the features.
My system is an HP Pavilion DM4 with Windows 7 and 4 Gig's of Ram on a 64 bit system.
Please help.
Posted Fri 26 Oct 12 @ 3:12 pm
Update your Pro Full. Seems to be to old.
Greets, Heiko
Posted Fri 26 Oct 12 @ 3:38 pm
Posted Sat 27 Oct 12 @ 1:43 pm
Hey Everybody,
Here we go again, I just got the VMS2 I installed the program VDJ LE and nothing i also have VDJ Pro and still nothing. I mean non of the functions work when i try to operate it. the cue, the load, the audio, nothing is relaying from the controller to the program. i installed all the new asio software. im working off a asus PC windows 7. I need help
Posted Sun 02 Dec 12 @ 7:17 pm
^^^ same problem. It used to work in LE version, but the upgrade sends no sound to the VMS2
I have followed these instructions. Doesn't work for me.
> Please deinstall "all" VDJ versions from your computer and delete the folder VirtualDJ (C:\..\VirtualDJ)
Backup the folder onto a USB stick.
> Clean your system incl. registry with a tool like the CCleaner or if possible use our tool:
http://www.virtualdj.com/addons/2170/Registry_Tool.html
> Download and install only the version from YOUR download center.
https://www.virtualdj.com/download/updates.html
After that please check the settings from VMS4.1. They are simular ;-)
http://www.virtualdj.com/wiki/VMS4%20/%20VMS4.1.html
Finally got it to work. Make sure to only use the VMS2 drivers from your LE cd.
Posted Fri 14 Dec 12 @ 6:07 pm
I can't set my vms2 for scratching with virtual dj pro.
Posted Sat 29 Dec 12 @ 11:23 am
Just to make sure, have you tried to set the jog-mode to vinyl on each deck with the button right to the shift button?
Another way could be, to set the jog-mode in the options from cd to vinyl.
These would be the first two points, which I would check. I hope one of them will fix your issue.
Posted Sun 30 Dec 12 @ 1:56 pm
I just bought a MacBook Air and I can't get the affect to work
Posted Sat 09 Feb 13 @ 1:52 am
hi I need help to reinstall virtual dj, I have the original CD but the serial has problem I cannot read the numbers verywell, for some reason a couple of letters have errased and now is not clear to read it. what can I do to obtain a new serial? thanks so much.
Posted Fri 11 Oct 13 @ 1:05 pm
Posted Sat 12 Oct 13 @ 12:37 am
69%
