Hi! I just bought an IDJ3 (started mixing a few weeks ago) and allthough its a siple controller I am happy with it. The only thing that I am missing is the presence of hot-cue buttons...
So I have been trying to replace the Mute buttons for the low mid and high with set_hotcue 1, set_hotcue 2 and set_hotcue 3. The problem is that I also need buttons for goto_hotcue 1, 2 and 3 so I figured I would use the Mute All button as a modifier to change the set_hotcue 1, 2 and 3 buttons to goto_hotcue 1, 2 and 3. Is this possible? If so what do input do i need?
Thanks in advance!
Thanks in advance!
Posted Mon 30 Jan 12 @ 11:15 am
you need to use the full version of vdj pro or activate the trial to map controllers
if you want the shift button to set the cues, otherwise go to the cue use this
mute all button
set 'shift' while_pressed
mute all button led
var 'shift' ? blink 400ms : off
eq kills buttons
var 'shift' ? set_cue 1 : goto_cue 1
eq kills buttons leds
hot_cue 1 ? on : off
just change the number "1" to the relevant cue number.
also you should be aware that hot_cue already sets a cue if none exists, and will jump to and play from the cue point if one is set. Goto_cue, will only set the song position at the cue point, so it won't play if the track is stopped of paused.
mute all button
mute all button led
eq kills buttons
Posted Thu 02 Feb 12 @ 9:15 pm
Thanks alot for the help! It worked! :D Im guessing I can set the shift button to change the knobs to effect/key modifiers? :)
Posted Fri 03 Feb 12 @ 2:47 pm
