Hi friends,
i have a problem. i use long time virtual dj pro and now i try configure typhoon but virtual dj not recognized.-
in the mappers appears only simple midi mapping and does not appear typhoon as it does with other drivers as the Denon 6000 so .-
i rescand and nothing!
i have version 7.0.5
pd: in version le work perfect.! but i need more options! y prefer long time version pro.!
do you have a mapper or a solution.?
Thanks.!
Juan.
Thanks.!
Juan.
Posted Fri 27 Jan 12 @ 11:31 pm
Do you have the latest VirtualDJ v7.0.5b installed?
http://www.virtualdj.com/download/updates.html
Check the MIDI device name in MacOS's Audio/MIDI utility.
It should be named exactly as follows:
TYPHOON DJ-Controller
If not, please rename it.
Posted Mon 30 Jan 12 @ 7:29 am
yeas i have a latest version.
in midi device audio midi utility i see name TYPHOON only
how rename??
Thanks. i Use snow leopard 10.6.8
Posted Tue 31 Jan 12 @ 3:19 pm
First, make sure that you are viewing MIDI devices, not audio. Click on the Window menu and choose Show MIDI Window.
Click on the appropriate MIDI device in the list. Then click on Show Info.
Click on the Device Name: box and type in the correct name: TYPHOON DJ-Controller
Click APPLY.
Click APPLY.
Posted Wed 01 Feb 12 @ 5:38 pm
Click APPLY.
Click APPLY.
Hi friend the typhoon dont show in MIDI device list, i change usb etc etc. but nothing.! no idea how add.i rescan midi and no see.etc i add device but no see to.! im crazy.!
and one think i dont understand, when connected via version LE machinne work, but in version pro dont.!
Thanks.
Posted Wed 01 Feb 12 @ 8:17 pm
Click APPLY.
Click APPLY.
now i rechange usb cables and i see in device. and test sound and work.! but now i go to virtual dj pro and dont work.? no see in list device
Posted Wed 01 Feb 12 @ 8:23 pm
Click APPLY.
Click APPLY.
now work friend.!!
i delete all
and reinstall everything.! now runn very good.!
many thanks.
Posted Wed 01 Feb 12 @ 8:38 pm
I just bought the typhoon and I'm having the same issue. Mine just shows "keyboard" and nothing else in the mapper drop down list. When you said you deleted all, did you uninstall the program and re-install it? Then it worked?
I plug in the typhoon and it's recognized in the input/output section but nothing in the mapper section and I get no response from the unit it self.
Posted Sun 05 Feb 12 @ 3:48 pm
Never mind. I tried installing a typhoon mapper but once I deleted it, it started working.
Posted Sun 05 Feb 12 @ 4:27 pm
If you had installed a custom mapper then it was most likely conflicting with the built-in native support.
No mapper is required to use the Vestax Typhoon - It's natively supported in VirtualDJ v7.0.5b
Posted Mon 06 Feb 12 @ 4:34 am
hi im having the same problem. ive done everything and still nothing works. im using windows 7 os. when i look in the drivers list i see typhoon dj controller but two of them, one hid compliant driver, usb input amd composite device. the vestax always had comflict issues but this time it simply cannot detect. none of the knobs and buttons work but e sound card still functions. i recently added a wireless keyboard and mouse and thats when the problem started. HELP!
Posted Fri 02 Mar 12 @ 2:52 pm
I am having a similar problem and require assistance
I have three laptops and none of them seem to be able to run VDJ and Typhoon. I cannot find Typhoon on the Mappers config listing. I have installed the software on my PC (win 7 - for all laptops as well) and Typhoon shows up no problem and works just fine.
Is there something I'm missing here about latops and PC's? I need to be able to take this Typhoon anywhere with my Acer laptop and want to use VDJ but I can't get it to work :(
Help!?!?!?
Thanks
Ty
Help!?!?!?
Thanks
Ty
Posted Fri 08 Jun 12 @ 12:17 pm
This is a topic in the Apple Mac technical support forum. For PC technical support, please post in the PC Technical Support forum: http://www.virtualdj.com/forums/20/PC_Version_Technical_Support.html
If the Typhoon doesn't show up in the full list when you untick the option to only show connected devices then it means that you are running an out-of-date version of the software.
Please register your serial number on the page http://www.virtualdj.com/users/edit.html and then download the latest version from the Download Center: http://www.virtualdj.com/download/updates.html
If it does appear in the full list but isn't detected, please see http://www.virtualdj.com/wiki/MIDI%20Controller%20Not%20Working.html
Posted Fri 08 Jun 12 @ 12:29 pm
hi to all,
got a used Vtyphoon but w/out the VDJ_le_v7.0 disc installer.should i download the driver VDJ_le_v7.0 driver. still have the code# on the typhoon.
thanks.
thanks.
Posted Sun 25 May 14 @ 9:19 pm
Your Typhoon VirtualDJ LE serial number is registered to your account so you can download the most recent version of VirtualDJ LE for it from your account.
Posted Tue 27 May 14 @ 4:40 am
