Forum: Old versions
Topic: MixTrack PRO + LIVE BROADCASTING + USING MIC
ok so i have a mixtrack pro i am a owner of an online radio station and i want to be able to mix live with my mixtrack pro and be able to use my mic can someone please help me if VDJ is not the software that i need could someone please tell me what i do need and how to do it as of right now i feel like i wasted my money on something that i can not do what i want to do with it i know there has to be a way to do this so can someone please help me thank you.
Posted Thu 26 Jan 12 @ 9:08 pm
Posted Fri 27 Jan 12 @ 1:50 pm
Hook your mic directly into your laptop, or you can hook your Mixtrack Pros output into the "line in" port on your laptop, then you can use the "advance" configuration settings to tell VDJ to pick up the sound from your "line in". Instead of having the "Main mix" come from VDJ, it'll play the audio it hears coming through the "line-in", but set it up so that the sound coming directly from the program is heard in your in ear mix, and use the second output on your board to run the music to your speakers. So you don't run into any delay issues.
There's options for ya :)
Posted Fri 27 Jan 12 @ 7:28 pm
