Forum: Old versions
Topic: Virtual DJ Pro with a Numark Mixtrack Pro
I have a Mixtrack Pro and was using the OEM Virtual DJ LE software that came wit it. I upgraded to the Virtual Pro, as I lost my OEM disk, and now i cannot seem to configure the Mixer correctly, it's only giving me one channel. I went into the configuration page, and it will only give me the $4 Channel mixrer option (LEFT - channel 1&2 : RIGHT channel 3&4). There is no 2 channel mixer option ( LEFT- Channel 1 : RIGHT - Channel 2), unless you do it in mono, and even in mono, i am loosing one channel on the mixer.
How do i configure it to work with my mixtrack pro ? How can I get a copy of the OEM software, if i cant find the original ? PLEASE HELP !!
Thanks
Posted Sat 14 Jan 12 @ 6:51 am
Please register your Pro serial number on the page https://virtualdj.com/users/edit.html and then download the latest version from https://virtualdj.com/buy/
You should also be able to retrieve your VirtualDJ LE serial number by contacting the manufacturer Numark: http://www.numark.com - Then register it to your profile using the link above (You can upgrade from LE for MixTrack Pro to VirtualDJ Pro at a considerable discount.)
For the correct configuration for MixTrack Pro, please see the following page: https://virtualdj.com/wiki/MixTrack%20Pro.html
