Forum: Old versions
Topic: Problem with usb or computer??? I have Buzzing noise when hooked up to my Pa system
Hey guys i just purchased the Hercules RMX Console. I have it working, but i can hear that my laptop is making noises like a buzzing or something that i can hear threw my pa system how do i fix this?
Also if i turn up my pa volume the buzz gets louder too
Here are my laptop specs
Computer - MSI Megabook VR700
Intel Core Duo CPU T2450 @ 2.00GHz
2 gigs ram
I am also running Window xp service pk 3
Hear are some Q's
Is my laptop good to run Virtual dj?
Are my usb plugins no good?
Do i Have my laptops master volume too high? (I have it maxed) Or does the asio audio driver take ove
Is my laptop's soundcard not good enough?
Im looking in on getting a new notebook like Asus, should i be looking to get one that is running a i5 core or higher and should the ram be no less than 4 gigs?
Any and all help is greatly appreciated Thanks, Jay
Posted Tue 06 Dec 11 @ 4:49 pm
The most common cause for noise like this is the laptop PSU. They're often badly designed.
When you encounter this noise, try taking out the PSU plug from the laptop so it's running on battery power.
If the noise goes away, there's your cause.
The easiest/safest/cheapest way to solve it is to use GLI's (ground loop isolators) between the laptop audio output and whatever it feeds.
thanks groovindj i'll look into that and keep you posted....
Another suggestion (quick, easy, and cheap - less than $1) is try plugging you laptop power cord into one of those ground eliminator adapters (usually orange or gray) that disconnect the ground from your power connection. I have been using one of these since I started using my laptop 3 years ago and it has helped tremendously.
ok guys guess what? No problem anymore!!! Because... I got a new laptop for cheap! It has an i3 processor with 4 gigs ram!
i think it was the computers ports. But now im having other issuses...
