Topic: Internet connection via cell / mobile phone - Help?
I've seen a few posts on here about using a cellphone to create an internet connection in order to download from netserach and the like with VDJ while gigging...(I Think!) Can anyone tell me how do to this via my iphone, if that is indeed possible?
Most places I do gigs dont have wifi available so it means I can't do requests using netsearch, but if I could somehow utilise my internet (3g mainly depending on area) via my iphone that would be great. Cheers!
Posted Mon 28 Nov 11 @ 4:27 pm
go to your provider and ask/look up "Tethering"..
All the Iphones, Androids, and blackberries are capable of it, but some providers require you to have a large data package before they let it work..
If your computer already has bluetooth built in, and your using windows 7, then its actually pretty easy..
If you need to use the cable, (depending on the phone) you may need to download software to help you with it..
Hi yes I have bluetooth, windows 7 and unlimited data package on iphone, what do I need to do?
cheers for the links and advice
seems i need to get a new iphone deal as my provider(O2) doesn't give me a free personal hotspot on my iphone unless I take out a new contract...grrrrr!!! good job I'm due an upgrade lol..
Jail break it......... Google is your friend bro.......
Good Luck
Huey
Good Luck
Huey
Like Huey said, Jailbreaking is the way to go. If you're looking for a tethering app on Cydia, MyWi 5.0 is the way to go...
