Forum: Old versions
Topic: Help a fellow dj out.
I keep getting the skin error message when trying to run my LE copy of Virtual dj. I can't seem to fix the problem, I would love to hear some suggestions.
Posted Sat 29 Oct 11 @ 2:39 am
The skin error message?
What skin error message? It might help if you quoted it!
And anyway, LE versions don't support using skins other than what's supplied with the software.
Have you tried reinstalling?
Posted Sat 29 Oct 11 @ 4:42 am
Does it say
Warning, the skin you are trying to use is too big for your screen resolution(or something similar)
If so don't worry about it, I get that all the time, doesn't make any difference :)
Posted Sat 29 Oct 11 @ 11:26 pm
Posted Mon 31 Oct 11 @ 1:36 pm
