Forum: Old versions
Topic: VDJ screen resolution problem!
hey there! i installed VDJ (FREE) and my screen screen resolution is 1024 by 768 , witch am using the same 2 deck screen resolution skin, but the problem is that i need to minimize VDJ to see/use my task bar (internet, MSN) how do i get it so i can still see the bar and not have it set to fullscreen?, i have had it perfect before but i installed windows vista fresh and now am getting this ? :S thanks for the help.
Brett.
Posted Fri 21 Oct 11 @ 2:22 pm
set your desktop to a higher res or use lower res on vdj.
If you use same res, it will take the whole screen, then use the WINDOWS keys to bring up taskbar/programs without minimizing vdj.
Check taskbar it might be set to AUTO HIDE.
Posted Fri 21 Oct 11 @ 2:51 pm
