Topic: 4 deck control with Hercules RMX Controller?
Hi, I've been using Virtual Dj for a year or two, and think its great so recently upgraded to Pro, and bought a Hercules RMX Controller, it makes such a difference, not sure how I managed using a mouse :) But was wandering if it was possible to use the controller to control 4 decks, by changing the mapper. For example, by holding down Scratch and Button 3 changing the left controlls to deck 3? I've Had a look through all the mapping codes and looked through the forums here and google but cant find anything that helps.
Posted Thu 06 Oct 11 @ 3:34 pm
Thanks a lot works perfectly :)
perodna comos e meten eso pa utilizar 4 eck n mappers?
Sorry, this forum is for English language messages only.
Please either post your message again in English or use the appropriate language forum at the bottom of http://www.virtualdj.com/forums to post in your own language.
you need to see the huge chunk of metal in the rmx that makes it heavy... CRAZY! The rmx works wicked with the skin cds4 and if you need help mapping it I will be happy to help you..
That chunk of metal its there for a reason....theres the story (somewhere around here )of the guy who took on a nite club gig which they had installed these HUGE Bass Bins.he had the baba brother of the RMX,a Cue mixer,see? all plastic.he could'nt figure out why his tracks were stuttering as soon as he "Dropped da Bass"..see?...it was the vibrations of the speakers making there way from the fllor to the Dj booth,and on to the little bitty Cue mixer.simple fundementals my dear watson....:P
The text:
select ? device_side 'left' ? deck 1 leftdeck ? on & deck 3 leftdeck & deck 3 select : on & deck 1 leftdeck & deck 1 select : deck 2 rightdeck ? on & deck 4 rightdeck & deck 4 select : on & deck 2 rightdeck & deck 2 select : select
Should be put in the "Action Learn" field, under Mapper, correct? If so, then it's not working for me. My PFL buttons still select 1 and 2 as normal. I'm using a Hercules RMX.
Sorry for dropping here like a "hair in a soup"
but is it possible to have 2 RMX controllers connected to one PC ?
Thanks !!!
Yes it is.
Pachn
there a lots of videos from it on the net but seems no one can get it to work properly.
What do you mean? 2 controllers and 1 PC?
Or 4 decks on a 2 deck controller?
