Hi, I got the Numark Mixdeck and I downloaded all the updates and install the Traktor-LE CD that came with it and updated the Traktor-LE to its newest version.
I'm using a new Macbook Pro 10.6.8. version software.
I got VDJ Pro 7 and VDJ Home Version.
I did everything that is suppose to be done to make the Mixdeck so it would work with the VDJ but nothing shows up. I went to mix with the Mixdeck using the the VDJ and when I go to config. sound settings, well there's nothing that says Mixdeck. Outputs and Inputs settings for Mixdeck isn't there, its all normal basic stuff that VDJ normal have on it, Like it says
"""Inputs: None
Outputs: External Mixer (deck1: ch1&2/ deck 2 ch3&4)
Soundcard: Mono Separated/ 2 cards/ 4-out cards ( they all say bulit-in output)"""
--Theres no ASISO driver that's shows up.
Also in Traktor-LE I used the Setup Wizard. i did:
1. "If you are using a USB/Firewire Controller." I answer: Yes.
2."Please select the manufacturer and model of your USB/FireWire controller from the listed below. The Setup Wizard will configure TRAKTOR to work properly with your controller. I answered: Choose "Numark" as manufacturer and "Mixdeck" as model.
3. "If you are using a Native Instruments (NI) audio interface with TRAKTOR the Setup Wizard will configure the audio routing." I answered No.
-Then it says the summary of what I answered and then I exist.
But I used to use the Macbook Pro 10.6 on my brothers one and it worked fine.
Also I did it on my Windows 7 and it all worked fine too.
I don' know if I got to download some special software for it to work on my mac. If so let me know.
****I need to know how to fix this problem ASAP cause i got a DJ for this Sweet 16 party on Oct. 1!!!****
"""Inputs: None
Posted Mon 26 Sep 11 @ 7:28 pm
If you are using a Mac, there is no such thing as ASIO on Mac. Mac uses CoreAudio for its sound.
Please see http://www.virtualdj.com/wiki/MixDeck.html
NOTE: Home FREE only supports MIDI controllers for 10 minutes at a time and cannot be used at gigs where you are being paid. To use MIDI controllers and/or play at gigs where you will be paid, you will need to purchase the full VirtualDJ Professional: http://www.virtualdj.com/buy/index.html
Make sure that you have the latest Home FREE installed: http://www.virtualdj.com/download/free.html
Posted Tue 27 Sep 11 @ 10:14 am
I got the full version of VDJ pro. it works fine. and my problem is that when i go to config. and then sounds setup there is nothing that says numark mixdeck on any of the choices! i installed all the updates and all the firmware and using VDJ pro 7 and i did the traktor setup like the step by step owners manual said but yet there's nothing!!!
Posted Tue 27 Sep 11 @ 11:11 am
In that case, please register it on the following page: http://www.virtualdj.com/users/edit.html
Most likely it's not working because you are using an out-of-date version that does not have any support for the Numark MixDeck.
If the MixDeck came with VirtualDJ LE, you can upgrade it to the full VirtualDJ Pro at a considerable discount by going to http://www.virtualdj.com/buy/index.html and entering your VirtualDJ LE software serial number in the box provided.
Posted Wed 28 Sep 11 @ 7:29 am
