Forum: Old versions
Topic: Help with recording!
Hey everyone, I am new to the forums and I know there is alot of talk on here about recording but I need a little bit of help. I am using my laptop connected to a versaport soundcard with two vestax turntables and then with that sound card running to a behringer mixer and then into a peavey 1500 amp. I used to record my mixes with ease on a small midi controller but now that I don't use it I am having a bit of trouble. I can hear both tracks in my mixes. I know that this has to do with the fact that Virtual dj cant tell what the faders position is. I need to know what I can do, either with my settings or additional hardware. Please help me out so I can keep putting out new mixes. Thanks for the help everyone.
Posted Fri 23 Sep 11 @ 5:59 pm
Posted Fri 23 Sep 11 @ 8:34 pm
I have read all of those help things and I am trying to get a little more help with my personal situation. I just don't quite get what it i saying. What is it that I need to do in MY situation?
Posted Sat 24 Sep 11 @ 7:23 am
Ok open the advanced config window and set it up like this,
Deck 1 - Versaport - Outputs 1/2
Deck 2 - Versaport - Outputs 3/4
Timecode 1 - Versaport - Inputs 1/2
Timecode 2 - Versaport - Inputs 3/4
Record Loopback - Your On Board Soundcard - Inputs 1/2
Now run a line out from the Booth out or Record out into your laptop. I've never used that soundcard so my numbers could be off but try that and I think you'll be good to go.
Let me know if that works
Huey
Posted Sat 24 Sep 11 @ 7:38 am
Ok now where do I plug the wire from the booth into my laptop? In the mic input? I tried that and it sounded loud and distorted. I don't have any special soundcard on my laptop and I dont have any rca inputs on it either.
Posted Sat 24 Sep 11 @ 3:56 pm
Is there any specific way i should run it back into my computer?
Posted Sun 25 Sep 11 @ 6:11 pm
