Forum: Old versions
Topic: Sound setup Problems (Need help fast!)
WozzWozHome userMember since 2011
So i have 2 CDJ-350s connected to my PC and Virtual DJ. Also have a Xone 22 mixer (no usb) connection.
Things worked fine untill i started getting some sound quality issues. I re installed the software and it worked, but now i can't get my Sound setup correct. Everything i try that used to work now has problems. Either the the music im playing on VDJ (Right or left deck) is comming from the opposite CDJ and the second option is hard to explane. But you get the point?
What should be my Sound setup options?
When it used to work, i ad it on Advanced Config --->
Deck 1, Left hand side CDJ, output 1&2
Deck 2, Right hand side CDJ, output 3&4
I dont really know what technical stuff i should tell you.
Please just tell me what to do :) I was planning to do a small party in a few days, but now this came up and i would like to get this fixed
Posted Wed 07 Sep 11 @ 10:37 am
Posted Wed 07 Sep 11 @ 10:48 am
