i have old soundcard audio 2 dj and it works with Virutal Dj v6 on Windows XP just normal, but now i buy new audio 2 dj soundcard Traktor Edition 2011 and instal on my laptop WIN7 and Virtual DJ v7 and i have problems , i have configuration 2 DRR2 GB-a RAM and 2,2ghz Intel celeron 900...
my problems:
- When i try to open song it take too long time in virtual dj v6 and xp windows and old audio 2 dj card on sam laptop it takes few seconds now it's too slow
-when i opet fail in virtual dj who have 75 minutes he wont open it he open empty space and when i try to play that fail nothing happend
can someone please help me
my problems:
Posted Sat 16 Jul 11 @ 10:06 pm
pleasee hellpp
Posted Sun 17 Jul 11 @ 5:46 am
VirtualDJ v6 is an old and out of date version of the software. There have been many changes and improvements to the software since then (See http://www.virtualdj.com/wiki/VirtualDJ_History.html ) - We are now on v7.0.4
Please register your serial number on the page http://www.virtualdj.com/users/edit.html and then upgrade to the latest version: http://www.virtualdj.com/download/updates.html
Or purchase the latest version from the following page: http://www.virtualdj.com/products/comparison.html
If you are using VirtualDJ for home use only without MIDI controllers/timecode/video, then you can download and use VirtualDJ v7 Home from http://www.virtualdj.com/download/free.html - This version can be used completely free of charge for non-commercial home use (It may not be used a DJ gigs where you are being paid.)
Posted Sun 17 Jul 11 @ 2:49 pm
you dont answer on my question i have Virtual V7 i ask you why fails open so slow in my virtual dj v7 in v6 version fails open much faster, is there any fuction in options because i have 2gb ddr and good enough cpu, so why my fails open with low speed in virtual dj v7??
Posted Sun 17 Jul 11 @ 3:08 pm
It fails because you are most likely using an illegally acquired version.
Also your system is most likely being bogged down with bloatware and not been updated with OS updates or cleaned up in a while.
Posted Sun 17 Jul 11 @ 3:43 pm
do you see what i write up , i have NEW windows 7 and i work on ilegal version 6 in past with win xp and everything it's ok now i have original virtual dj v7 and new win7 and he open my fails too slow? and biggest problem is that he wont open fail who are larger about 70 minutes
Posted Sun 17 Jul 11 @ 7:34 pm
can someone pls write me how to set options in virtual dj v7 and how to set option i ASIO drivers i have external mixer and audio2dj soundcard, thanks
Posted Sun 17 Jul 11 @ 7:38 pm
I use the new audio2 as well and it works perfectly although ive noticed it does load the system a bit. For the record a Celeron 2.2 is a poor CPU too!
It would suggest an issue with your system.
Uninstall VDJ, clean up and install the latest home edition. Open and set sound configuration and try again.
Posted Sun 17 Jul 11 @ 8:36 pm
i have one but i got the same problem on mine its says error check your audio card its not connected
Posted Thu 26 Sep 13 @ 4:38 am
It won't work with your LE version - it requires you to connect and use your RMX.
Posted Thu 26 Sep 13 @ 5:19 am
