Hi everyone, I'm about to upgrade to VDJ 7 Pro and also get some vinyl turntables and the audio 6 and hook it up to my new Denon MC6000 because it looks like I can't use it as a DVS.
I really like the Traktor Vinyl Timecodes and I was wondering if they will work with Virtual DJ Pro 7
Thank youy very much
Posted Sat 09 Jul 11 @ 11:58 pm
There my second choice when it comes to timecodes. First are Numark Virtaul Vinyl, 2nd Traktor and 3rd Serato.
Good Day
Huey
Good Day
Huey
Posted Sun 10 Jul 11 @ 12:34 am
Thank you very much! I was about to get the Rane-CV02 but based on your comment i'm going to get the Second Generation Traktor timecodes!
Posted Sun 10 Jul 11 @ 6:42 pm
Do the traktor second generation time code vinyls work with vdj 7?
Posted Fri 01 Jun 12 @ 4:01 pm
I dont think the latest traktor timecodes work with vdj. I couldn't figure out how to get them to work.
Posted Fri 01 Jun 12 @ 10:11 pm
Hi did now traktor scratch timecode mkII is work with VDj7 ???
Posted Fri 08 Mar 13 @ 3:21 pm
You will need VirtualDJ Full Pro version to use Timecodes.
Traktor mk2 vinyls are not supported but you have other options.
Posted Sat 09 Mar 13 @ 2:46 pm
I use Serato CV gen two based on the suggestions on VDJ PRO
Posted Mon 11 Mar 13 @ 9:45 am
