Running windows 7 (x32). Dedicated machine, nothing else loaded. used machine for 1 year without no problems. directx 10.
Running all videos. Output on vga - 2nd output full screen.
After loading the latest version, (7.0.4), about every 30 minutes or so, the virtual dj desktop will "duplicate" itself and paste a 2nd phantom image of itself about 3 inches to the left of itself. The video on the output is ok and continues to play (thank God), but Totaly confused as I do not know where the buttons are. I did figure out that if I "minimise" the right picture and re-maximise it, it will be ok again. for about 30 min anyway.
Posted Thu 30 Jun 11 @ 11:44 pm
This is what it should look like. Looks like some sort of directx bug. Never did this before the latest upgrade. Any Ideas? (already did a "reset to defaults" routine to no avail.) Greg
Posted Thu 30 Jun 11 @ 11:46 pm
mine has started to do the same did you sort it out
Posted Mon 21 Oct 13 @ 7:05 am
ATI Radeon HD 5XXX series ?
Posted Mon 21 Oct 13 @ 7:08 am
Did you update the drivers
Posted Mon 21 Oct 13 @ 7:20 pm
You posted on a thread that is two years old, and that guy may not be here. What video card do you have?
Posted Wed 23 Oct 13 @ 12:01 pm
