Forum: Old versions
Topic: Help - Problem with everything key related.
I can't turn on the keylock (above the tempo changer). It goes yellow when i hover and click but doesn't stay on. I am usually able to keep it on but for some reason, it's not working anymore. Also, the effect 'key changer' isn't doing anything anymore, and the 'key' dial (next to the filter) isn't working and doesn't have the white line (indicating the level) on it.
I'm new to this software so it is probably a simple solution like a preference or something, I'm just unfamiliar with the interface.
Cheers
Posted Sun 19 Jun 11 @ 7:20 am
Check your keylock setting in CONFIG -> Performances
If it is set to Pure Scratch (No Master Tempo) then keylock/master tempo cannot be used.
Posted Sun 19 Jun 11 @ 7:18 pm
