Forum: Old versions
Topic: Mixdeck cross fader problem! please help!
So I just picked up my Mixdeck today i am running VDJ 7.0.2 LE and I'm having a problem with a the cross fader. When i have it all the way to left and both tracks playing I hear both of the songs but when i move the fader to the right I hear nothing at all. If i have the fader all the way to the left i should only be hearing the song on the left but I am hearing both.
Any suggestions? Do i need VDJ pro or can i do it on LE?
Please help :)
Posted Thu 19 May 11 @ 10:13 pm
First, please ensure that you have the latest VirtualDJ LE v7 installed: http://www.virtualdj.com/download/updates.html
And the latest drivers and firmware from: http://www.numark.com/mixdeck
Then go to CONFIG -> Sound Setup and set your sound as follows:
Inputs: None
Outputs: External Mixer
Sound card: Numark
Click APPLY.
Make sure that the channels on the mixer section of the MixDeck are set to PC.
that works unless recording it just records both decks at the same time....
thanks for the help worked out great!
