Forum: Old versions
Topic: CDJ 800, MAYA 44 USB, MAC help
Hello,
I recently purchased 2 CDJ 800 MK2 and I would like to use them on my VDJ the problem is I cant get VDJ to use the maya 44 soundcard. When I select Timecode on the config menu VDJ stops responding so when I press play nothing happens I can still use some functions but I cant play the tracks. Also VDJ doesnt seem to respond to my CDJ's when I put the timecoded cd's in.
This is my current set up:
Left deck -> Maya analog in 1/2
Right Deck -> Maya Analog in 3/4
Maya analog out 1/2 -> Left channel mixer
Maya analog out 3/4 -> Right channel Mixer
On the mac I have these settings:
Maya control panel: Monitor 1/2 - 3/4 Halfway, Mute, Gang on
Input: Halfway, Gang on
Output Halfway, Gang on
Audio Midi setup:
Aggregate device: Selected Maya 44 USB
Configured speakers to: Quadraphonic
In VDJ:
Inputs: Timecodes: Chan 1/2 Leftdeck Chan 3/4 Right deck
Outputs: External Mixer (DJM 400)
Sound Card: 4 in 4 out card. Aggregate device (maya 44 usb soundcard)
Am I doing something wrong? Or am I missing something?
Any help would be really appreciated.
Kind regards,
Posted Sat 14 May 11 @ 4:43 am
The only thing you have to do on your Mac is that
And that
and on your VDJ that
Don't do anything more mystic...........
Chris
Posted Sun 15 May 11 @ 11:11 am
Thank you for responding,
Got it working thanks to you really appreciate it, Now the only problem is the timecode config how do you get the quality to stay at 100%?
I use the Timecoded CD offered at VDJ, but it is kinda glitchy (pitch suddenly moving, when I press play it takes about 2 counts to get it to start in vdj). Did you do somehting to get it like that?
Kind regards,
Posted Mon 16 May 11 @ 1:35 am
