Forum: VirtualDJ Skins
Topic: I'm stuck on a skin, please help
I'm stuck on this skin. I just bought VirtualDJ, and I don't seem to find a way to change out of this skin...
Please, help me into finding the config key on this skin or tell me how can I access the configuration panel out of this skin.
Please help, I appreciate it.
Thanks.
Posted Fri 13 May 11 @ 11:32 pm
Oh my, I just noticed you can't see the skin I'm stuck on, please help me finding a way how to change my skin. I don't seem to find the config key on this skin, how can I change it?
Thanks.
Posted Fri 13 May 11 @ 11:35 pm
what skin are you using? Is it the default 2 deck skin?
Posted Fri 13 May 11 @ 11:50 pm
clemo91Home userMember since 2011
Im having a problem where the skin is like three quarters on my screen and a bit is missing and i have had a play with the resolution but it just wont change at all it either goes wider or thinner and i cant fully see the deck at all!! its winding me up!! help!?
Posted Sat 14 May 11 @ 8:29 am
Remove the skin from the skins folder. What skin are you using?
Huey
Posted Sat 14 May 11 @ 9:45 am
