Forum: Old versions
Topic: Maya 44, Numark DXM & Laptop.......Hook-Up Help
DJZERRYPRO InfinityMember since 2011
Hi Group,
I am trying to connect my set up..
My set up is the following
Virtual DJ Pro
PC Laptop with windows
Numark DXM06
Maya 44
Two Monitor Speakers , which are hooked up to the Left & Right Speaker jack o the Mixer
(I am not running any CDJ or Turntables at all)
I have the Maya 44 connecting the the USB outlet on the side of my PC Lap top
But the problem I have is I am not sure at all on connecting the Maya 44 analog 4 in and analog 4 out
to the mixer and the mixer
Your help would be great as my dumb-azz is sitting her on hold
Thanks
Posted Sun 08 May 11 @ 3:20 pm
just put the outputs into the line in on the mixer specifically
output 1 & 2 - mixer input channel 1 L & R
output 3 & 4 - mixer input channel 2 L & R
make sure you have set the switches above the inputs to line.
Finally you don't need to worry about the inputs at this stage, they would be used for sending a timecode signal (either vinyl or cd) into virtual dj to control the transport of the track.
Posted Sun 08 May 11 @ 6:11 pm
Great thanks!!!!!
Posted Sun 08 May 11 @ 9:26 pm
