Forum: Old versions
Topic: serato sl1 box settings with cd player ?
jm12910Home userMember since 2011
hello im new to the forum and recently picked up 2 pioneer cdj 1000s with the serato sl1 box . serato is okay but it doesnt give me the precise bpm for each song that I was looking for like vdj does . I choose to play the right deck on 1 and 2 and left on 3 and 4 but when I try to start a song only the right deck will play . The left deck will show movement if I move the platter but wont start the song . do i need another soundcard for the left deck to play or ? any help would be appreciated thanks
Posted Sun 24 Apr 11 @ 11:04 am
anyone know how to get the sl1 box to work with virtual dj ? both cdjs not just one
Posted Mon 25 Apr 11 @ 7:03 pm
I had close to the same issue I believe...
When Configuring your set up, make sure to go into timecode config, and change your timecodes accordingly. I recommend using the VDJ timecodes http://www.virtualdj.com/products/hardware.html#timecode, and not the Serato ones.
Hope that helps
Posted Tue 26 Apr 11 @ 1:49 pm
djnandsPRO InfinityMember since 2007
HI JM12910,yes Vdj works with serato sl1,thats what i use,and its very simple,you have to download ASIO4ALL drivers and follow the instructions in vdj´s user guide.
You can either use serato´s time code,or virtualdj´s time code,both are good.
Posted Sat 30 Apr 11 @ 12:39 pm
