Recently purchased a mixtrack pro a month ago and it comes with VDJ LE. I go the free month trial of VDJ Pro and everything was working fine with the controller when i opened VDJ LE. Now the trial is up and my controller doesn't work at all. Do you have to have VDJ Pro to use your controller? Why the hell do they even give you VDJ LE if you eventually have to buy VDJ Pro. . . or am i doing something wrong. I am supposed to DJ a floor party for my dorm tonight but my controller isnt working... a fast response would be wonderful. THANKS!
Posted Mon 07 Feb 11 @ 12:12 pm
fast response would be awesome....
Posted Mon 07 Feb 11 @ 12:13 pm
Please allow a reasonable amount of time for somebody to respond. 1 minute is not enough.
Of course VirtualDJ LE works with the controller it was included with.
Please check that you have the latest VirtualDJ LE installed from the Download Center: http://www.virtualdj.com/download/updates.html
If it is not working, then you may have chosen settings in the Pro trial that or not compatible with or available in LE.
With the software closed, delete the following file: MacintoshHD -> Users/YOURNAME/Library/Preferences/com.atomixproductions.virtualdj.plist
The software should revert back to its default factory settings - You may need to re-enter your VirtualDJ serial number.
Posted Mon 07 Feb 11 @ 12:35 pm
I am having the same problem. The mixtrack pro controller works with VDJ Home for the 10 min allowed...but it doesnt work with the VDJ LE that came with the controller? I downloaded the latest version and still nothing. The installation disc reads v6.7.1 or so but my macbook pro wont even recognize it to install so I downloaded here, with the product key.
Im extremely new this, and a little lost. Why would it come with LE if I have to end up buying Pro?
Posted Tue 29 Mar 11 @ 3:12 pm
First make sure you plug in the controller THEN turn on your VDJ LE.
Posted Tue 01 May 12 @ 11:32 am
