I've always wanted to have a timed automix with virtual dj. It's a feature that is native in PCDJ and can be set to any value you want in the menu screens
I am not good at the vdj scripting language (yet) and I know how to write it out logically, but the actual coding.. ??
here's what I'm thinking, maybe you guys can tell me a script that will get the job done
if songpos deck default <=410sec do nothing else automix
I know that isn't correct but hopefully the logic is illustrated
Ideally I would like to have a text field on the skin where I can input a time that will be used as the value of the "timed automix" I will settle for a multi-button or a slider/knob though.
I'm pretty sure this should be do-able, just need the scripting know-how.
Thanks guys!
DjChuck
Thanks guys!
DjChuck
Posted Tue 18 Jan 11 @ 2:10 pm
Not sure if this is possible I will look into it for you.
Posted Tue 18 Jan 11 @ 2:35 pm
This cant be done. VDJ script doesnt support time triggered actions. Just remember that any actions you add in an xml file, there has to be combined with a button, or a slider, etc. So yes you might write a script like this but it will be triggered ONLY when a button is pushed or a slider is moved.
Each time you press a button on the screen, VDJ looks at the code and makes this or the other, but not automatically.
Posted Tue 18 Jan 11 @ 3:09 pm
Looks like another feature the team could look into for the future, time triggered actions? Very interesting.
Posted Tue 18 Jan 11 @ 4:04 pm
Quote :
Well poop. That sucks. well I agree with killadj, maybe they can add this capability in the future
Thanks for the attention guys.
Posted Tue 18 Jan 11 @ 11:01 pm
