Got an Iphone 5... Bought the software... my mac doesn't recognize The iphone.
HELP!!!
HELP!!!
Posted Tue 12 Mar 13 @ 8:51 pm
Please see http://www.virtualdj.com/wiki/iRemote.html
Posted Wed 13 Mar 13 @ 6:35 am
when there is an update, could there be a search option as i'm used to using the feature on VDJ 7.
to use the folder and track selector seems to take more time to find the track and load it up so the remote is pretty much useless apart from starting and automixing the tracks.
Would be really good if this feature could be added.
Posted Mon 15 Apr 13 @ 6:07 am
Search and a full screen browse too please.
Posted Mon 15 Apr 13 @ 9:48 am
Is a droid app available for remote dj?
Posted Wed 22 May 13 @ 1:26 pm
No
Posted Wed 22 May 13 @ 1:31 pm
Please help.. Driving me Crazy! (and sorry for long post!)
I am trying to connect iPhone/iPad to PC (Windows XP with up to date SP's etc).
I have latest and full version of VDJ.
PC is wired to same WiFi router used by iPad.
iTunes/Bonjour are installed and up to date.
iPad connects to internet ok
I can ping the iPad from the PC.
For clarification I have tried the following:
WEP and WPA etc
AES & TKIP etc
All firewalls (PC & Router) Off.
If I use a WiFi dongle on PC and set up ad-hoc network I can connect without problems (except for the usual connection dropping out problem).
Therefore this *must* be a problem with router but I cannot figure out what!
Any help would be much appreciated.
CD
WEP and WPA etc
AES & TKIP etc
CD
Posted Sun 09 Jun 13 @ 9:49 am
I by accident hit the enable button thats removed the ipad from the list of devices si there a way to get it back?
Posted Mon 15 Jul 13 @ 7:05 pm
Check your Apps in iTunes - should be already in the list. Just mark it for reinstallation.
Greets, Heiko
Greets, Heiko
Posted Mon 15 Jul 13 @ 11:33 pm
I have just downloaded everything I need for the iremote but my lap top is still saying I need to download Bonjour Print Services for Windows v2.0.2 I have already done this please help !!!!!!!
Posted Wed 14 Aug 13 @ 3:47 pm
CD
CD
You should check your security settings on the router. Some have an option to prevent connections between devices.
Greets, Heiko
Posted Wed 14 Aug 13 @ 11:25 pm
Ipad with Virtual DJ Remote
I'm hoping someone might have an idea:
I loaded Virtual DJ Remote on my Ipad but I am unable to connect to my computer with the Ad-Hoc network. I believe I did everything correctly but when I try to access the Ad-Hoc network I get an "unable to connect" message. Anyone have any ideas?
Posted Sun 25 Aug 13 @ 9:18 pm
Hi!
I have paid Virtual Dj for Ipad and download from App Store but it doesn't work. it doesn't What should I do?
Alex
Alex
Posted Sun 08 Dec 13 @ 6:48 am
Are you running the Software itself on MAC or PC ?
Greets, Heiko
Greets, Heiko
Posted Sun 08 Dec 13 @ 7:56 am
PC
Posted Sun 08 Dec 13 @ 8:03 am
Did you install iTunes & Bonjour Services from Apple ? As i remember the Bonjour is part of the iTunes installation.
Are the PC and the iDevice you are using for iRemote in the same Wireless Network and see each other (not blocked by Firewall or Router) ?
Greets, Heiko
Greets, Heiko
Posted Sun 08 Dec 13 @ 8:35 am
Yes, I have installed BonJour
Posted Sun 08 Dec 13 @ 8:53 am
Which version of Virtual DJ are you using exactely ?
Posted Sun 08 Dec 13 @ 9:17 am
In my computer I have Home Free, and in my IPad remote
Posted Sun 08 Dec 13 @ 9:19 am
adamlonsdale wrote :
Hey. I'm having a bit of trouble using this. I have VDJ opened with "Enabled" set to true on the iPhone tab. I load up the app on my phone and it just says "Trying to locate Virtual DJ" Any ideas? I'm guessing theres a specific port that I need to unblock
Cheers,
Adam.
Cheers,
Adam.
Posted Sun 27 Jul 14 @ 2:33 pm
