Forum: Old versions
Topic: VDJ audio quality sounds poor compared to Serato Itch - Solutions
I am using a Mac with the latest VDJ 7.01 full version and am having issues with the audio quality sounding right. Something's off with VDJ audio compared to Itch, the sound is wavy, almost like a small flanger sound. I compare the same songs across the board with itch compared to VDJ and there is a noticeable difference. Does anyone have any good solutions/ideas?
Thanks
Posted Fri 03 Dec 10 @ 2:14 pm
If you are using master tempo (Keylock), make sure that you have set it to use high quality stretching under CONFIG -> Performances (Unless you have a slow computer that cannot handle this.)
I have the Numark Ns7fx and I'm using a MacBook Pro 13 inch with intel core duo Processor, 2.4 ghz speed, 4 GB Memory, Bus Speed 1.07 GHz, I'm having problem with Virtual Dj 7. I keep getting the wave sound that some people are having. Is the a way that you guys can post a picture or video on how everyhing is to be set. Please help this is the third computer I buy.
I have the ns7 and i got the same wave sound but the sound desapear when you turn of the plater the wave sound desapear my tip is start the song with. The plater off then put the motor on and works good
