Forum: Old versions
Topic: Can I Timecode With ESI U24XL USB Sound Card??? (IMPORTANT)
please tell me
Posted Fri 17 Sep 10 @ 11:17 am
Well it's only got one stereo pair, so you can only input one channel, and only output one channel too.
For timecode you really want two stereo pairs.
so,i cannot do it? or it won't sound as good?
It's not the best solution; it would give you extremely limited functionality.
Your soundcard is not something you should scrimp on.
and how can i do it with my card?
what will i need? how to connect?
What card?!
As I've said this card is not really suitable.
You only have one input. This means you can only connect one turntable to it.
You only have one output. This means you can only have one output channel (1 deck, or the master output for example) unless you bodge it with a splitter.
As I said do yourself a favour and buy a card that is suitable for the task.
i have only one turntable atm so,i will stick to this one for now
If you're intending to mix you'll really want *two* stereo output pairs - one to play out of and one to use with your headphones.
