Forum: VirtualDJ Skins
Topic: Mixstation 3.0 - Page: 2
Shaggypoet : It’s not a bug. My skin is in conformity with the default skin of the 3.0 version :
> Leftclick = Beatlock becomes smooth beatmatch (see the history of the 2.1 version)
> Rightclick does beatlock.
Serge.
Posted Thu 09 Jun 05 @ 7:57 pm
Serge,
Got it. Thanks man.
Would be great if you could post what some of those buttons do on this skin. Master Tempo, Scratch button and others. It might be easy for professional Virtual DJ folks who have been using all the versions of Virtual DJ for a while, but for newbies sometimes a little explanation even if its obvious is helpful. Overall, I like the progression of this skin.
One suggestion, would be nice to see this skin in red. Let's say the gray parts are red and the Black parts white, the blue black, etc...Just a suggestion to give folks more options.
But definitely, a guide which each skin should be included so that folks know where everything is at rather then just experimenting for hours to find out what one button does.
Keep up the good work.
Gracias,
VDJ Batibiri
Posted Thu 09 Jun 05 @ 10:32 pm
JeremKPRO InfinityModeratorMember since 2004
You have just given me a very good idea shaggypoet.
A guide for using each skin.
Anyway, be sure i'll put that in my next skin!
Posted Thu 09 Jun 05 @ 10:53 pm
FruitPRO InfinityMember since 2003
Posted Fri 10 Jun 05 @ 9:46 am
