Hi
I bought some denon dns 1200 and and his mixer.
Everything is correctly installed, but i can't get the tracks of vdj on my denon displays.
I just need to know how you configure that..
Thanks
Thanks
Posted Wed 30 Jun 10 @ 8:24 am
(1) What version of VirtualDJ are you using?
(2) Are you using a PC or Mac?
(3) Do you have the latest firmware from http://www.denondj.com installed on the Denon DN-S1200's?
NOTE: This question has nothing to do with VirtualDJ plugins/add-ons and should be posted in either the PC or Mac technical support forums (As appropriate.) Once you have replied with your answer to the above questions, it will be moved to the appropriate forum - http://www.virtualdj.com/forums/20/PC_Version_Technical_Support.html or http://www.virtualdj.com/forums/61/MAC_Version_Technical_Support.html
Posted Wed 30 Jun 10 @ 12:32 pm
