@ djtouchdan:
Man can you do a resize in this resolution: 1366x768? :)
Thank you very much,
Gabriele DiJ
Gabriele DiJ
Posted Sat 22 May 10 @ 5:47 am
1366x768?? As this will not be standard resize this might take some time, but i will have a look at it.
Posted Sat 22 May 10 @ 6:27 am
Their are so many great things about this skin I wont bother to get into it (would take to long)
a few issues I found..
When I hit the fullscreen button I was unable to go back to "window" size
It looks likes theirs an option "Wave form=V split or default".. but its not working.. A third option would be nice, default & no CBG
As to the top waveform.. the Yellow on Yellow makes it tough to distinguish between songs.. (IMO) I would stick the the standard Red/Blue
The Cue bottons are awesome.. the delete button is kinda dangerous though, would their be a way to make it safer?
Posted Sat 22 May 10 @ 6:57 pm
@ Hippy.had the maximes issue also.Just resize it to a smaller size than your screen.I got a 1280x800 but went further smaller so it makes some space for my side gadgets...lol... then i changed font size too a larger size (@ 18?) but more important,this fixed a loop point bug.seems if the skin is larger than what i use the waveform (code?) its off so loop points end up ahead and off by a mile!! after resizing it got fixed !! Huh i would make the slider buttons color darker so it dont blend with everything else when they are all the way to the top (or bottom) of the slider.the waveforms color should be opposite of each other shadewise so i agree with that. humm otherwise a ROCKIN SKIN !! DAN is DA MAN !! he,he
Posted Sat 22 May 10 @ 7:35 pm
Not all together sure what you. The maximize button in the top right?? Seems to working fine here??
This function does work however there appears to be a fault with the multibuttons at the moment. I have asked a member of the Team to look at it.
If you select the option from the drop down menu then click on the text it works.
djdad has suggested that i lose the drop down box and just have the text cycle through. So click and get deafult, click again and get v-split and so on....
I find that there is enough distinction between the two, however i will look at swapping things over. Orange and Yellow are my colours of choice for BlackSheep, however i have been thinking about making a Red & Blue version.
Excellent point - what about if i made them so you have to "double click" the button to delete it. That would be safer??
Posted Sun 23 May 10 @ 6:18 am
thats the one.. I double check with the other skins I had, Blacksheep was the only one that did it. it would maximize and just stay that way..?? weird.
Quote :
OK.. got it working..yes. probably getting rid of the drop down box would probably work best (and just cycle thru)
Quote :
I think its because the Red/Blue has become so standard.. you dont have to think about which one is which..
Quote :
Or a rightclick.. how about a single button? Left click "renames", and right click "deletes" ??
P.S. :
Unless I missed them.. i dont see the 'locks' or video fader options on the skin..
"video_crossfader_auto" & "video_crossfader_link"
Posted Sun 23 May 10 @ 12:03 pm
@hippydog you are dealing with an 1440X900 skin. Are you running this resolution or another? It matters if you run the skin in maximize.
Posted Sun 23 May 10 @ 1:30 pm
Testers - Check Your Inbox
Posted Sun 23 May 10 @ 2:19 pm
I would like to be a tester. Is it to late dj touchdan?
By the way ...you're the man... nice skin.
Posted Sun 23 May 10 @ 5:17 pm
can i get to test this little puppy? =)
Posted Sun 23 May 10 @ 5:43 pm
Oh Great!! I got to Resize and Change fonts on two more of this !!...Lol....To HIPPYDOG...Like I says Resize it smaller than your screen (the Wide Resolution Its what i tend to do Though you get a message with the SKIN RESIZER that it might not be proportional but i dont need space on the top or bottom,i do so on the right side...) and it will maximes.You'll want to change the Browsers Font size unless you like Streessing your EYE SIGHT( I got 20/20 and plan to keep it that way ..Lol...) Otherwise a Good job DAN !! One SEXY SKIN !!!
Posted Mon 24 May 10 @ 8:07 pm
What I really liked about this screen was its ergodynamics.. IE: you don't have to really "guess" what a button does in most cases, it just seems to be obvious.. nicely laid out yet with full usefullness.
Posted Tue 25 May 10 @ 12:16 am
I loved the older version however when my laptop model choice changed, thus so did its screen size/resolution change, I stopped using it. With the multiple resolution choice available, I'm definitely back on-board.
I would really enjoy getting into the Beta Testing class.
I would add one request without even seeing the skin first hand...a reverse version. Many times we are operating the software outdoors and during the day. It is impossible to see the screen and dark software with reflections of everything including a white tux shirt to deal with.
Please, is it at all possible to have a day time version?
Posted Tue 25 May 10 @ 5:43 am
you can try opening the bitmap image in paint and then select invert, that may help with the day time problem.
Posted Tue 25 May 10 @ 6:55 am
Or even easier, you can use the Skin Resizer with the "Outdoor" option to reverse the colors of the bitmap and all font colors.
http://www.virtualdj.com/addons/7187/Skin_Resizer_Tool.html
Posted Tue 25 May 10 @ 8:19 am
Cap Capello wrote :
I loved the older version......
.....I would really enjoy getting into the Beta Testing class.......
Cap Capello - Glad you liked v1 and are looking forward to v2.
Unfortunately the Beta period is now drawing to a close. The full version should be uploaded in the next day or two to the site. Pending approval should be available soon after that.
As suggested you can invert the image or use the skin resizer tool to make an outdoor version - but hey - who knows i might bundle one in with the release :)
Posted Wed 26 May 10 @ 4:08 pm
Hi Dan,
Tested both on Win & Mac at 1920 x 1200, both seem fine but the graphics from the BMP seem a bit "stretched" at that resolution. I guess you made the skin smaller and resized it up?
Keith
Keith
Posted Thu 27 May 10 @ 12:13 pm
Thanks Keith will look at doing a image resize without 'stretching' it. Shouldn't be a problem.
Do you prefer the blue and red version??
Posted Thu 27 May 10 @ 4:13 pm
Thanks!
I personally do but the original colours look good too.
Having both colour schemes would be like a woman having two handbags!
Posted Thu 27 May 10 @ 4:50 pm
