Virtual DJ 6.07
Windows 7 (64bit)
Intel Core 2 Duo CPU E8400 @3.00GHz (overclocked to 4.05GHz)
NVidia 780i SLi motherboard
Maya 1010 Sound Card
2 -NVidia 9600GSO Video Cards
When I run Virtual DJ and play a song (video or audio) on the left hand side player it will play fine and then will get garbled, if I start a song on the right side it clears up this only happens on the left side.
I am running Virtual DJ on the "Best Quality" with safe mode. I can check the ultra latency mode and it will clear it up for a few minutes and then will get garbled. I have used dpdat.exe and it stays in the green.
IT IS NOT A LATENCY ISSUE, just sounds the same.
I can run the on the same computer with the same settings using Windows 7 (32bit) and it runs fine with no problems.
I want to be able to run it on the 64 bit version to give me a better video output and to use more RAM to keep the system idoling smoothly.
Thanks for your help
Skipper
Windows 7 (64bit)
Skipper
Posted Mon 29 Mar 10 @ 4:08 pm
