Topic: Can Native Instruments Maschine(VST mode) work with Virtual DJ?
I've recently bought Maschine with the added MIDI Controller and i was wondering if the software could work with Virtual DJ as a VST?
I've seen several uses of Maschine as a VST for Traktor and Ableton live. I wonder if the same could apply to Virtual DJ?
Anyone tried Maschine working in VST with Virtual Dj?
Posted Wed 03 Mar 10 @ 7:29 pm
yes it works but you must program it for your self.
for me it works fine.
Machine is a midi controller you can do want you wound.
have fun man
Can you share your mapping?
Can you share your mapping with us??? I am also interested... I have mapped Ableton Live and Maschine nicely but would like to see how you did it with virtual dj
just a heads up, guitar rig 5 works pretty well.. you can select your effects in the vst window then map your sliders to any controller... it has crashed on me a coulple of times when changing effects within the vst window though. If that works maschine vst should run but not sure how to map it correctly without seeing it.
Can any one share the MIDI setting to control Virtual Dj with Maschine?
