Numark - NDX800
Play, scratch, and effect CDs, MP3s, USB, and software.
NDX800 is high-performance control for DJs who blend different kinds of music sources. Whether your music is on CDs, MP3 CDs, USB flash drives, or your computer, you can play and manipulate it with NDX800. This digital deck has the feel and layout you’re used to, with a twist of Numark innovation.
FLEXIBLE FORMATS
NDX800 has a large touch-sensitive platter for controlling, cueing, and scratching your music. NDX800's smooth, fast, reliable, slot-loading drive works with both CDs and MP3 CDs. You can also connect a USB flash drive for access to thousands of MP3s without taking a computer or CDs to the gig.
But this advanced deck isn’t just an MP3/CD player – you can also use it to control software. Just connect NDX800 to your Mac or PC with a single USB cable and you’re seamlessly controlling the music on your computer. MIDI communication enables you to easily map virtually any DJ software for direct connection from your fingers to software.
DYNAMIC DECK
NDX800 has an advanced platter that is touch-sensitive for superb accuracy and smooth control of tracks on discs, flash drives, and software. The big, seven-inch platter is surrounded by an illuminated ring that acts as a position display, just like putting tape on vinyl. The platter's touch sensitivity is adjustable so you can optimize its performance for the way you like it.
You'll appreciate NDX800's smooth, quick, slot-loading disc action. The deck has our Anti-Shock™ electronically buffered skip protection to keep the music playing reliably when the floor get packed. You can also adjust NDX800 to perform just like vinyl on turntables thanks to start and stop-time controls.
The deck has Auto Cue, Instant Start, and Stutter Start for quickly and easily playing the track the way you like. Track selection is a breeze with a rotary control, and you can play back tracks in single, continuous, program, and shuffle modes. Fader Start enables NDX800 to start playing the track you have cued up when you move the crossfader on a compatible mixer for effortless transitions.
FX FLAVOR
On top of playing all kinds of music media, NDX800 enables you to add flavor to your performances with integrated, beat-synced DSP effects that include chop, echo, filter, flanger, pan, and phaser. Each is completely adjustable and a dedicated wet-dry fader controls them all.
PITCH POWER
NDX800 contains a set of beat and pitch tools that will help you with beat matching and harmonic mixing. Start playing a track and NDX800 automatically analyzes its BPM (tempo), and displays it on screen. There’s also a Tap tempo button for manual BPM entry. You can alter the track’s BPM by ±6, 12, 25, and 100% using the pitch fader. For each of those ranges, you can also engage Key Lock, which holds the pitch of the track while you independently manipulate its BPM. There’s also a set of pitch-bend buttons on each track for quick tweaks and you can adjust pitch in half steps (semitones).
REAL TIME REMIXING
NDX800 gives you a complete range of remixing tools for on-the-fly creativity. NDX800 has an internal sampler with overlay and reverse settings so you can easily grab samples while you work and trigger them on the three sample/hot cue trigger pads whenever you want. NDX800 also has seamless looping on a set of easy-to-understand controls including adjustable loop-out point. Numark’s familiar Bleep/Reverse gives you the ability to keep time moving forward while you cut or reverse the track. Five stutter starts and cue point memory storage round out this powerful deck's remix capabilities.
VIVID VIEW
NDX800 features a large, backlit display for keeping tabs on the deck even in poorly lit conditions. You can monitor BPM, CD and MP3 text ID3 tags, navigate folders, and keep an eye on effect status on this big, bright screen.
NDX800 is the powerful, versatile deck for playing and controlling all kinds of music media. Whether you play parties, clubs, events, or in a group, NDX800 gives you the feel you like, the look a professional demands, and the utility of built-in effects, remixing, looping, and sampling. Pair a couple of NDX800s with your favorite Numark mixer and start making some hips move.
http://www.numark.com/ndx800
FLEXIBLE FORMATS
DYNAMIC DECK
FX FLAVOR
PITCH POWER
REAL TIME REMIXING
VIVID VIEW
Posted Wed 13 Jan 10 @ 5:08 pm
che differenza ci sarebbe con i vecchi iCDX? ...non sarebbero male con il mixer pioneer DJM-5000, spesso è più difficile trovare console profonde, invece che larghe ed una sopuzione poco profonda permette di avere il PC davanti invece che in posizione "torcicollo" a fianco.
...insomma , tanti prodotti nuovi e tutti da scoprire, e pensare che c'è ancora qualcuno che compra i cdj-100 nuovi e poi magari vuol usare i timecodeCD, degustibus !!!!
Posted Wed 13 Jan 10 @ 7:28 pm
qualcuno li ha provati? online ci sono pochi video ma nulla di serio.
Se sono come gli icdx promettono bene. cmq numark ha portato molte novità per il 2010 bisognerebbe approfondire.
Posted Wed 27 Jan 10 @ 12:35 am
sono stati presentati circa 10 giorni fa....Diamo il tempo al produttore di distribuirli :)
Posted Wed 27 Jan 10 @ 3:52 am
Infatti... ma ho trovato poche cose di loro in giro per il web. Avevo trovato una bella offerta x un icdx usato poco (300 euro) e numark se ne esce con tutte ste novità... Io in realtà uso una xponent e il pc lo uso solo con questo tipo di controller ma un cdj in più non mi farebbe male... Come supporto... Ma ora Nn so proprio che pesci pigliare... Forse dovrei rinnovare la mia vecchia consolle... aspetto di saperne di più per questi cdj o per rinnovare proprio tutto magari con una mixdech o un paio di v7.
Professori date sfogo ai suggerimenti e alle notizie :)
Posted Wed 27 Jan 10 @ 7:29 am
Pare sia senza scheda audio come iCDX e per 40-50€ di differenza di prezzo secondo me conviene senza pensarci tanto un Pioneer CDJ-400, super collaudato e gia mappato su VDJ.
Se vogliono venderlo secondo me devono stare attorno ai 450€ di prezzo, 500€ son troppi se paragonato al Pioneer che ad oggi si trova anche a 540€.
Posted Wed 27 Jan 10 @ 8:11 am
...infatti... scusate se esco un attimo dall'argomento... vedo che mi esce no licenza etc. come mai? io ho registrato la mia licenza. Forse dovevo usare un altra mail per registrarmi qui. Tra le altre cose di recente ho comprato una Hercules per un mio cuginetto... prime armi come dj e mi è uscito anche l'ultimo Vdj ma con la mia xponent ... ho difficoltà ad usarlo....mahaa... appena ho un pò più di tempo torno ad usare il caro vecchio Vdj come facevo con la mia cara Hercules. Tornando ai cdj mi piacciono... mi sanno molto di icdx anche se credo che i cdj400 sono ancora un gradino più in su. Cmq complimenti alla numark per tutti i prodotti lanciati... credo che incideranno molto e comporteranno un calo del prezzo dei diretti concorrenti.
Posted Wed 27 Jan 10 @ 9:19 am
Per risolvere i tuoi problemi con la licenza contatta l'assistenza http://it.virtualdj.com/contact/index.html
Posted Wed 27 Jan 10 @ 9:55 am
Posted Thu 25 Mar 10 @ 4:54 pm
