Reduce the latency and improve the scratch quality?
When scratching get an annoying digital sound :(
When trying to scratch or cue the tracks using the vinyls... it misses beats... it's not very acurate.
Currently using 2 technics 1200s MK2 and Hercules RMX.
Posted Tue 12 Jan 10 @ 2:07 pm
You need to set up your timecode correctly then; it doesn't randomly skip beats for me.
http://www.virtualdj.com/wiki/Timecode%20Config.html
Latency is dependant upon your computer and system settings. Ensure VDJ latency is set to ASIO, then use the lowest latency you can in your soundcards settings. If you can't get low, have a search on the forum for DPC latency.
Posted Tue 12 Jan 10 @ 2:34 pm
SBDJ wrote :
You need to set up your timecode correctly then; it doesn\\\'t randomly skip beats for me.
Latency is dependant upon your computer and system settings. Ensure VDJ latency is set to ASIO, then use the lowest latency you can in your soundcards settings. If you can\\\'t get low, have a search on the forum for DPC latency.
I remember I used to see the ASIO option, now dont see it anymore.
here you have a screenshot of my timecodes.
Will look a work around for the ASIO issue, if you know one please let me know.
above issues still persist
Posted Wed 13 Jan 10 @ 12:24 am
DPC latency Appears to be for PC not for mac....
Posted Wed 13 Jan 10 @ 12:41 am
You forgot to mention the Mac part - you can forget about my post in the case!
One thing, you're running 1ms latency and want it lower?
Posted Wed 13 Jan 10 @ 3:17 am
Yeah... still not accurate :(
and forgot that
Posted Wed 13 Jan 10 @ 3:20 am
Continue the discussion in the other thread you started. Please don't crosspost topics :)
http://www.virtualdj.com/forums/122222/MAC_Version_Technical_Support/latency_and_sound_quality_issues.html
Posted Wed 13 Jan 10 @ 6:45 pm
