Purchased a RMX last week
My setup is as follows
Hercules RMX connected via USB to my laptop
Hercules is also connected to my hi fi via the output 1 and 2 connectors using RCA connectors
Im running Windows 7
In the sound card setup when i tick the" apply EQ to external" box the music i play keeps jumping about
When i untick this box every time i move the crossfader, gain button, volume etc i get a garbled, distorted type of noise coming through my speakers.
Can anyone give me a solution? Im at a loss here.
Thanks
Thanks
Posted Tue 29 Dec 09 @ 2:06 pm
mate have you mapped your buttons yet or wrong maybe.or make sure you have latest drivers for rmx can be found on hercules website.
Posted Tue 29 Dec 09 @ 2:35 pm
Do i need to mapp first? What does this do?
Sorry for sounding a bit thick but i only bought the RMX on christmas eve
I installed the latest drivers.
Music just keeps jumping about every few minutes
Thanks
Thanks
Posted Tue 29 Dec 09 @ 2:56 pm
Also in the DJ Console should my setup not be WDM?
Itr keeps going to ASIO
Posted Tue 29 Dec 09 @ 3:00 pm
Virtual DJ will work in WDM unless you check the box APPLY EQ ON EXTERNAL SOURCES. This will then switch to ASIO
A few things you shoul do.
1) Apply the changes explained in this guide:
http://ts.hercules.com/faqs/eng/her_eng_00364.pdf
2) In the DJ Rmx Control Panel, switch to ASIO audio mode, and in the ASIO tab, configure as follow:
- 44 Khz
- 16 bits
- 480 (10 ms)
3) Launch VDJ. You will probably have an ERROR IN THE SOUND DRIVER message, but this normal.
For Sound Setup, configure as follow:
- Input : None
- Output(s): Headphone
-Soundcard: DJ Console Rmx,
then check the box APPLY EQ ON EXTERNAL SOURCES, then click APPLY.
Use VDJ for a while and see if you still get problems. If so, You can raise or lower the ASIO Buffer Size until you find the correct setting for your computer 9this needs to be done while VDJ is not running).
- 44 Khz
- 16 bits
- 480 (10 ms)
- Input : None
Posted Tue 29 Dec 09 @ 3:30 pm
Thanks for the reply.
I uninstalled the RMX drivers and also VDJ
Cleaned out all temp files and old registry files.
Rebooted.
Installed the RMX drivers again. This time however i wasn't connected to the internet
Rebooted
Installed VDJ
Rebooted
My config is now setup as not having ticked the 'Apply Eq to external inputs'
So far i dont have any garbled sound when i use the cross-fader, gains buttons etc
Fingers crossed it stays that way...if not then i'll try what you described above.
Thanks for your help.
Maybe when i was connected to the internet Widnows tried to install its own driver? Who knows.
Rebooted.
Rebooted
Installed VDJ
Rebooted
Posted Tue 29 Dec 09 @ 4:03 pm
answer to you other question mapping allows you to set whatever you want rmx to do from each button.
first i would get it working in normal\ mode as vdj will just work with it,
then in mappers settings in config make sure rmx console shows up on top of left hand side.
when you click on it a list of all you buttons will come up.
then you can map each button using vdj script.
once you get this sorted the fun begins have had mine for over a year now and best buy ever after vdj
Posted Tue 29 Dec 09 @ 4:04 pm
