Hi isyahtiger87
I use two programs first Total Commander and then KJ file manager by Latshaw for Karaoke files to futher check dup's down to MFG., Disc#. and track numbers or there maybe someother veriation that would make that track different so careful attention is needed for Karaoke files.
Total Commander Link: http://www.ghisler.com/
KJ Manager Link: http://www.latshawsystems.com/Products.aspx
Joey...
Joey...
Posted Thu 03 Dec 09 @ 8:37 am
Hi Joey,
Yes, it's a text file. I was under the impression that the "remove duplicates" action failed becuase it was a bug, but since it is apparently not a bug, I will just write an app that will remove the duplicates from the saved playlist.
Thanks for all the help
Posted Thu 03 Dec 09 @ 8:43 am
Hey abeukes
Very cool, once you write it and use it would you let me know how it all worked out for you.
Thanks
Joey....
Thanks
Joey....
Posted Thu 03 Dec 09 @ 9:09 am
JoeyKJ wrote :
Hi isyahtiger87
Joey...
Joey...
Not familair with Total Command. Does it work well and how does it handle mp3's. While thinking of it is there a good tag proggie out there as well that would seem to help me with dupes as well.
Posted Thu 03 Dec 09 @ 10:40 am
for tagging I user MP3 Tag Tools v1.2 , great tool.
http://download.cnet.com/Mp3-Tag-Tools/3000-2170_4-10073195.html
and Total Commander works great with all types of files, MP3 included.
Posted Thu 03 Dec 09 @ 10:52 am
Hi isyahtiger87
There is Tag&Rename which I have and also very good, you can try Link: http://www.softpointer.com/tr.htm
One more for you is Tagscanner very interesting still CIO Link: http://www.xdlab.ru/
Good Luck
Joey....
Good Luck
Joey....
Posted Thu 03 Dec 09 @ 11:44 am
Posted Thu 03 Dec 09 @ 2:24 pm
DuplicateFilesDeleter is a simple, but effective tool to locate duplicate files in one or more selected search paths. It scans the files and compares them based on Byte for Byte Comparison, which ensures 100% accuracy. You can then choose to delete the selected duplicate or original files. The program is multi-threaded and performs scans quickly.
Posted Fri 08 Jan 16 @ 7:47 pm
Thank you for your addition to this topic, last visited in 2009.
LOCKED BY AMAHM
LOCKED BY AMAHM
Posted Fri 08 Jan 16 @ 10:44 pm
