Hello :)
I just purchased the hercules rmx, but every time i'm opening VDJ a window pops up that says: Error in Sound driver ?
i'm using mac
Please help ?
i'm using mac
Please help ?
Posted Mon 09 Nov 09 @ 10:36 am
Be sure to install the latest driver for the console (v1.77, link below ), as well as the latest update for Virtual DJ (5.2.2), available from the Download section of this site.
http://ts.hercules.com/eng/index.php?pg=view_files&gid=2&fid=28&pid=215&cid=1
Posted Mon 09 Nov 09 @ 12:28 pm
Tubse1992 wrote :
Hello :)
i'm using mac
Please help ?
i'm using mac
Please help ?
This works >>
use another sound configuration, so here is the conf:
You simply have to choose the "4-out card" in the soundcards, and then selects the Hercules RMX in the field "driver 1", and then I select the output channels as "Master: chan 1&2 Headphones : chan 3&4"...
Posted Thu 12 Nov 09 @ 2:13 pm
Hi Tubse1992,
Please make sure u connect/attached the controller first to the mac before booting the system up.
Also as mentioned by DJ Phatso, do install the latest driver and update your software to the recent ones;)
Regards;)
Regards;)
Posted Thu 12 Nov 09 @ 2:35 pm
i just recently bought HERCULES CONSOLE RMX. when using virtual dj i cant hear anything when i press play, i have speakers set up which work. i dont understand, it wont allow me to sample or play anything. when i press play, not only does it have no sound but the track itself does not play. im very new to this and really need help.
thank you.
thank you.
Posted Thu 28 Jan 10 @ 8:15 pm
jsteb,
I have posted an answer to your same message on http://www.virtualdj.com/forums/123225/MAC_Version_Technical_Support/none_of_my_tracks_will_play__please_help_.html , please don't post 3 times the same message at the same time, let to the community the time to post an answer.
Posted Fri 29 Jan 10 @ 3:53 am
