Topic: How to get automix on deck B to to use Mic on deck A for stream?
Heya all.. well my question in all the the title; i'm streaming over a lil radio station with a Hercules RMX, now all i was able to do is get the RMX Mic output on deck A ( and the RMX talk over function isn't that clean).. i was wondering if there was a way to automix on deck B so i could lower the volume on deck B and raise deck A a lil higher so my voice would come out a lil more louder over the music .
Btw a couple of times i've managed to get the automix on deck B.. don't ask how but i just did, pure lucky just click on automix and it was on Deck B.
Posted Mon 02 Nov 09 @ 11:00 am
To automix on deck B, have a track playing on deck A when you start the automix.
Roy
To DJAol > Automix on deck b... make sure you are playing on dack b first, and make sure the headphone is selceted for deck b
then load your playlist up with your tracks, and press the automix button on the playlist pannel.
then find your mic in the lefthand pannel and you can load that on deck A.
on your controller, lower the volume of deck b to 50% when you want to talk..
Virtual DJ dosent do auto talk over. for this you would need a mixer with this feature, then the above method would not work the way you want it..
Ty u all for the great help ^^
