Forum: Old versions
Topic: I just got stanton str8-60s, im using hercules rmx as my mixer...need help with settings!
I have a macbook pro 13inch snow leopard
2 stanton str8-60s
hercules rmx
what settings do i use to play vinyl?
and another question--do i need different settings if im doing regular vinyl or timecode? I would like to play both =]
Posted Thu 29 Oct 09 @ 8:49 pm
It is pretty simple
- Connect your turntables to the input 1/2 and 3/4 on the back of the Rmx. Don't forget to also connect the ground to the appropriate screw, and set the switch to PHONO.
- In the Rmx control panel, for Deck 1/2, be sure that the select source is LINE In
- Launch VDJ and then press the SOURCE button for each deck. This will tell the software that you want to use external sources. Start playing your turntable and the audio should normally come out of your speakers.
If you want to mix an MP3 on you computer, simply press again the SOURCE button for that deck.
Note that if you want to use Timecoded vinyls, you will need the PRO version of VDJ.
