I've just bought a Hercules Remix with the default VDJ software and everything is working fine etc BUT:
There is no control panel - it just says "More" and to upgrade. Surely the default software has a control panel for me to create shortcuts, adjust cross fader settings etc?
Please help!!
Please help!!
Posted Tue 20 Oct 09 @ 9:58 am
Indeed, this version, which can only be used with the Rmx btw, has no configuration possible.
It was meant to provide a software that worked out of the box without having to wrestle with configurations. Obviously, it's problematic if you want more,, but you are also entitled to a rebate if you want to purchase the Pro version:
Posted Tue 20 Oct 09 @ 11:14 am
Thanks you're a star - thanks for confirming my fear :)
Posted Tue 20 Oct 09 @ 11:24 am
