my purchase is imminent lol........Who has done the initial set up and who here can assist me with that when the time comes?
Posted Sun 11 Sep 11 @ 8:23 pm
![](/image/7149/71568/SCS1 asio driver.jpg)
Posted Mon 12 Sep 11 @ 10:53 am
If you let me know in advance, I can help you, skype stylee
Posted Mon 12 Sep 11 @ 10:55 am
nice Ill be hitting you up soon n thanks...
was wondering though.....effects within Vdj...are they native to the softwear...effects like echo delay etc like found on the controller of the numark ns7 ns6 and v7.
If these types of effects for the music playing are not build into vdj is there a way to input these effects via an external effects processor aux on the stanton mixer?
Posted Mon 12 Sep 11 @ 1:21 pm
Yes the FX are internal to VDJ
Posted Thu 15 Sep 11 @ 7:07 pm
djreff wrote :
what exactly do you mean ......................??????????????????? do tou mean launching da router?
thanks in advance
Drimachus wrote :
Did you run the Asio driver?
djreff wrote :
hey guys, finally the mapping fot the scs.1m is out. thanks for this one.
the only hic is that i'm not able to get the sound card of the mixer going (asio stanton 1394)
any help would be appreciared
thanks
thanks
thanks in advance
when i launch vdj, all the controls work ie : sliders pots, but again there is absolutely no sound, the strange thing is with other soft i'm able to get sound but obviously i would prefer using vdj, any suggestions would be greatly appreciated
thanks in advance
Posted Sat 17 Sep 11 @ 7:50 am
and you've gone into the settings menu and set the soundcard as stanton asio??
You might also try the factory reset of VDJ, then put the soundcard as the stanton
Posted Sun 18 Sep 11 @ 4:43 pm
I recently bought 2 Stanton T.92 Turntables and some serato timecoded vinyl, I can not seem to get the VDJ Pro Full Version 7 Software to work with these turntables. I also have a hercules DJ Console RMX. I have the 2 Turntables connected to the Hercules RMX console and the console attached to my Laptop... What should I do to fix this?
Posted Tue 04 Oct 11 @ 4:12 pm
Well cross posting is what you shouldn't do....
Posted Thu 06 Oct 11 @ 7:37 am
Have anybody been able to map Stantons newer SCS.4dj controller to VDJ ? ? and IF so - would you share this pls ? :-)
I have tried but really not getting anywhere as i dont really understand xml and the coding things i've read on the VDJ Wiki. I've been in dialog with Stanton who mentioned they have sent somethings to VDJ so it will be natively supported at some stage.
However that just leaves me with a non workable controller up until this is done... which is sad as i'm a true VDJ believer and would be really sad to be forced to switch dj software due to this :-/
Anybody? heeeeeeeeeeelp :-)
Posted Mon 24 Oct 11 @ 5:36 am
I recently purchased the Stanton scs system 3. I could not resist the price of $299. So far so good. Do any of you guys have any suggestions or things that I should know? How about a few tricks? I am open to any advice that you guys have!
Posted Mon 24 Oct 11 @ 4:02 pm
You will need to select "timecodes"
The select ASIO-Rmx
Do the timecodes set-up
And you will probably need to go to the "scratch" screen and set it to "relative", not smart relative
Hope this helps.
Posted Sat 29 Oct 11 @ 11:32 pm
I haven't seen any vdj maps for the 4dj.
Posted Sat 29 Oct 11 @ 11:35 pm
Remember that you can change the jog sensitivity, and the crossfader to work audio, video, or both
Posted Sat 29 Oct 11 @ 11:38 pm
does vdj work with Stanton SCS-1 Digital DJ System
cioce
Moderator
Last version 7.0.5 yes but I have not tried ;)
Just to be crystal clear, what about the scs.1d specifically? Is it supported and accurately scratchable yet, or are we gonna have to hope for this in Virtual DJ 8?
cioce
Moderator
Posted Mon 21 Nov 11 @ 12:40 am
Yes, the SCS.1 System ( SCS.1d and SCS.1m ) are both currently supported in the latest version 7.0.5b.
And no you don't have to wait for VirtualDJ version 8.
You can see a quick demo here - http://vimeo.com/30149583
And the whole system here - http://vimeo.com/29281932
*These are just demo's that they work ... don't critic the skill :)
Posted Fri 25 Nov 11 @ 2:31 am
That's great news! NS7 is too small and Denon 3700 has gone up in price (from 650 to 750 recently). All other non-motorized controllers are a joke for a turntable replacement. I would love to use a Stanton STR8-150, but my DJ coffin is already too heavy. Word to the wise, don't buy a full size DJ coffin ever! Get your flight cases separate so it's easier to carry and store.
How does the SCS.1d work with Virtual DJ? Did they use darouter, write support for the hi res midi, or something else? I would like more insight when you have time. Thanks!
Posted Wed 30 Nov 11 @ 9:58 pm
How would be possible to make the (SCS.1D's) motorised pitch work as it works with other programs (like Traktor)... when I change layer (from deck A to deck B) to "remember" the value of the pitch and when I change back, than the slider move to the "remebered" position???
Without this function I can't use my gear vith VDJ (what I want to use.... I don't like Traktor that much)
Posted Fri 30 Dec 11 @ 10:59 am
Good evening,
I have just 're-found' an old final scratch soundcard/controller, does anybody know if this can be used with the vdj software?
I have the timecode vinyl and all that, but I would prefer to use this software.
Thanks for your time
Posted Wed 29 Feb 12 @ 3:51 pm
lol, in theory yeah, but you might want to consider spending a little money and moving up to a more recent soundcard, like Numark VV, Traktor or my fave the deejay Trim...
Posted Thu 15 Mar 12 @ 10:23 pm
