Hi all
Haven't had the Macbook Pro long and at first everything seemed to work fine. I'm running the Hercules RMX, VDJ 6.0.2 on OS Snow Leopard.
Now I have frequent problems. The issues are surrounding the controls on the RMX. There is a problem with the start/stop buttons. When I want to start a track nothing happens. Most of the other controls are working, e.g. the treble knobs work - you can see them changing the treble on the software mixer. The issue is with the start buttons. Nothing happens. I have fiddled around and it seems to fix itself if I go into Settings> Sound Settings and then reselect Hercules RMX in the drop down box. The start buttons then work for a few tracks, before, they stop working again, and I have to repeat the reselect of the Hercules RMX in the drop down box.
This is really quite crap, any suggestions as to why this is happening? I'm a bit annoyed as I would have thought that this software would work ok on the Mac.
Thanks
Thanks
Posted Sat 19 Sep 09 @ 11:29 am
Try this,
Open VDJ - make the changes you have done before where it works. DO NOT PLAY ANYTHING.
Exit the software. This should then save the settings.
Re-launch the software and see if it fixes the problem.
If not - let me know and i'll have another think.
Posted Sat 19 Sep 09 @ 11:54 am
hey there,
Mac snowleopard and hercules rmx - with new drivers
it seems that i too have this problem.
when i loaded the new hercules driver today for a half hour it all worked fine - i mapped some buttons and then all went tits up.
now the play / stop buttons dont work at all (yes i checked their maping) i then reset, reloaded the software and alas - the play / stp buttons dont work. and VDJ6.02 crashes randomly too. so nada - soooooo disappointed as i was looking forward to a big mix sess.
has anyone else had the problem
Posted Sat 19 Sep 09 @ 1:28 pm
I'm still running 10.5.8 and had a similar problem after installing the VDJ update and RMX firmware update... I got around it by going to Config, then hitting Apply.... (Hercules Rmx was showing in the "Sound Card:" box)...
Posted Sat 19 Sep 09 @ 5:21 pm
djtouchdan wrote :
Try this,
Nope, thanks for the suggestion Dan but not doing it. Tried this several times and no joy. Its odd, when I hit play on the RMX the blue LED shows on the unit, but the music doesn't start. When I go into config, sound settings, and click 'Apply' it starts. It will play for a while then 'drop out' again when i load another track and I have to go into settings and click 'Apply' again.
Just to check - I'm using version Firmware version 1.0.31.6. in the Hercules RMX Control Panel and have installed the drivers dated the 17/9/09 from Hercules TS.
Also, I am now (this morning) quite frequently getting VDJ closing unexpectedly on start up.
Help!
Posted Sun 20 Sep 09 @ 3:51 am
+1 on what djeddiekay said. I too have to got to config and hit apply to get my RMX to play. I only have to do it once when I first start VDJ and then its fine.
Andrew.
Andrew.
Posted Sun 20 Sep 09 @ 1:22 pm
@andrewsmith86 @djeddiekay
Ok, those of you that are having to reset everytime. Have you changed your permissions to the VDJ folder in Documents to READ & WRITE.
@richphillips
try downloading this mapper by coice - see if this solves your problems. http://www.virtualdj.com/addons/8336/Hercules_Mapper_Pack.html
@richphillips
Posted Sun 20 Sep 09 @ 1:54 pm
thanks Dan, they're already configured that way... the problem seems to have resolved itself... sometimes "Restarting" isn't the same as "Shutting Down" then "Restarting" maybe the firmware update just needed a kick in the ass 8-\
Posted Sun 20 Sep 09 @ 8:22 pm
