I get this error . Need help.
Posted Sun 26 Jul 09 @ 2:50 pm
Have you got NOD32 as antivirus?
Posted Sun 26 Jul 09 @ 4:10 pm
yes and i quit nod32 before installation.
Posted Sun 26 Jul 09 @ 4:23 pm
Try to read that:
http://www.virtualdj.com/forums/105923/PC_Version_Technical_Support/Installation_error___Disable_NOD32_anti_virus.html
maybe it can help you
Posted Sun 26 Jul 09 @ 4:26 pm
Uninstall everything then using Reg tool in download section delete reg entries (cant remember exact wording).
Reinstall with nod 32 turned off, then turn on nod, start VirtualDJ allowing it internet access it will confirm valid installation over the net.....
should then be alright.
Normal install does not require internet verification, but if there has been a protection error it puts up a red flag that needs to be cleared over the internet.
Posted Sun 26 Jul 09 @ 9:07 pm
PROBLEM SOLVED . Thank you very much.
I had to uninstall completeley nod32, not just turn off.
Posted Mon 27 Jul 09 @ 7:53 am
Getting a "PROTECTION ERROR 2" now that I have attempted to install the latest updates. I am running McAfee OAS if that has anyting to do with it.
HELP !!!
HELP !!!
Posted Sun 19 Jun 11 @ 7:29 pm
Please contact support: http://www.virtualdj.com/contact/index.html
Also, please do not bump old topics from 2009.
[Old topic closed]
[Old topic closed]
Posted Mon 20 Jun 11 @ 6:26 am
